RainbowTaskbar, a rainbow for your taskbar
- Kappa
- 1 sept. 2023
With RainbowTaskbar, you can configure your Windows 11/10 taskbar and change its appearance to suit your preferences, as it gives you more options than the default Windows settings.
You can add rounded corners to the taskbar, add a rainbow effect, make the taskbar transparent or opaque, customize taskbar elements and much more.
When activated, RainbowTaskbar continues to change the color gradients of the taskbar according to your customizations.
A dedicated interface for configuring taskbar options is available. So you can customize the color gradients you wish to apply to your taskbar.
RainbowTaskbar also lets you configure preferences such as solid tint, solid fade, faded gradient, gradient, randomized color, hold time, fade time, gradient angle and number of layers. It also lets you select colors for changing gradients.
Of course, you can just use a simple gradient shade without fading :-))
RainbowTaskbar is a free portable application, so no installation is required.
If not already installed, you will be prompted to install the .NET 6 runtime (x64; x86).
But be careful! :
RainbowTaskbar conflicts with TranslucentTB. If you're a fan of the TranslucentTB utility for managing taskbar opacity, please disable it before running RainbowTaskbar.
For more information on configuration options :
Full official documentation: RainbowTaskbar Doc
Download : RainbowTaskbar on GitHub
Official website : RainbowTaskbar
